End of Line Constant returns only LF when deployed on cRIO
LV2011 SP1: I have found that when I assemble a string to use with the TCP Write VI, I get a different result using the End of Line Constant depending if I am running the project from LabView versus running the project deployed on the cRIO-9101.  In both cases, the project is running on the cRIO, but when run from LabView, EOL constant gives a CR LF.  When run from startup on a deployment, I get only an LF.  I have worked Arturo the issue by explicitly replacing my EOL constants with a CR and LF on my Concatenate Strings block.
On an earlier version of LV (9.6), I did not have this problem with the same target.  The discrepancy has only occurred since upgrading the program to LV 2011.
Any ideas?
(5,752 Views)
This symptom may have been related to a mismatch in cRIO firmware (LV2011) and development software (LV 2011 SP1).
(5,744 Views)
Hi Ken, as noted here:
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/end_of_line_constant/
The EOL constant is platform dependent so it will vary from platform to platform.
DylanC
(5,742 Views)
DylanC,
I understand that, but it doesn't explain why it would have one meaning when running targeted and another when running deployed.
(5,740 Views)
Accepted by topic author Ken_Brey
Hi Ken,
I have found a CAR (Corrective Action Request) #148678 that describes this issue. There is currently no patch/release that fixes this yet but the current workaround is to concatenate the two manually, as you have done. I apologize for any inconvenience this has caused.
DylanC
(5,738 Views)
