Epos & Real-Time compatibililty
Hi there
I tried to run an example program of EPOS which requires a download of an epos dll into the RT,
but it failed constantly showing the error message of [error] LabVIEW: Failed to load shared library
EposCmd.dll:_VCS_GetProtocolStackName@16:C on RT target device.
I found a similar topic on this issue, http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/More-than-1-ms-MOMO-digital-IO-7358-in-LabVi... .
I have tried the possible solutions given, reinstalling and pre-installing the softwares, and also Network Variable Engine and Variable Client Support, as shown in
http://digital.ni.com/public.nsf/allkb/F7201E81C39639B88625714C004A67F3?OpenDocument .
Could I confirmed if its a compatibility issue that perhaps the epos dll does not work with Real-Time?
The example program however works through Labview itself without Real-Time.
I need it to work with real-time as the project also involves FPGA.
I'm using an epos2 24/5 along with NI 9012 and 9104.
Thank you
Hafis
Message 1 of 1
(3,940 Views)
