Error -50400 when reading data from NI-9234 module.
Hello Professionals,
I'm in deep trouble, my application needs to read vibration signal from a motor (lawn mower engine), using NI-9234 module and then generate inverted and shifted vibration signals using a shaker (inertial) to cancel the effect of original vibration (from the motor).
So I'm thinking to perform this in three parts:
1. Vibration acquisition from motor.
2. Signal processing
3. Signal generation
The constraint is, I'm pretty new to RealTime and FPGA modules and also to Vibration signal analysis/processing and the immediate issue that I'm experiencing is when I'm reading the vibration signal using accelerometer (piezoelectric), my program is throwing an error (-50400) with following message:
--------------------------------------------------------- Error Message ---------------------------------------------------------
Deploying XDNodeRunTimeDep.lvlib:loadnilvce.viXDNodeRunTimeDep.lvlib:loadnilvce.vi loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library nilvce.*:niLVCtrlEngineReserveProc:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
My setup consists of:
cRIO chassis: 9113
cRIO controller: 9024
Module 1: NI-9234
Module 2: NI-9263
Module 3 & 4: Empty (not in use)
My project is also attached.
Please help me with your experience and knowledge.
Thanks in advance.
(5,526 Views)
Also going through the above application requirement, please suggest if the approach is correct or not.
(5,514 Views)
