01-20-2022 05:11 AM
Hi
When I try to upload a bitfile to a cRIO-9063 from NI MAX, LabVIEW or a web browser, I get the following message:
"There was a problem updating the firmware for this device. Error code: -52003"
The bitfile is uploading correctly on another cRIO-9063 I have.
RIO driver version: 18.5.
Any suggestion?
04-09-2022 12:54 AM
Did you manage to solve the problem?
I have a similar problem (the same error) when trying to upload FPGA programming file to the FLASH memory of a sbRIO board. The FPGA runs just fine with the same file loaded from labview
