Error 65008 occurred at Invoke Method: Read TEDS in NI 9233 Getting Started(Host).vi
In an attempt to run the project "NI 9233 Getting Started" which is an example provided with Labview 8.5.1 installed on ny computer, an error shows up.
"Error 65008 ocurred at Invoke Method: Read TEDS in NI 9233 Getting Started(Host).vi"
possible reasons: CompactRIO:(Hex0xFDF0) CompactRIO does not support the TEDS sensor connected to this channel.
I am using Labview 8.5.1, cRIO 9014, NI 9233 module, Impact Hammer Type 8206, Triaxial DeltaTron Accelerometer Type 4524.
Any idea.
waleed.
(3,754 Views)
I want to use the example "NI 9233 Getting Started" which is an example provided by labview in acquiring impact and acceleration. I am using Labview 8.5.1, cRIO 9014, NI 9233 module, Impact Hammer Type 8206, Triaxial DeltaTron Accelerometer Type 4524. I do not quite understand the different VIs available in the example and their roles. Should I deploy the subVIs and use them to enter some data? Are their any tutorials available elaborating the use and running of this example? Please help me out. Best Regards, Waleed.
(3,751 Views)
Greetings 4445.
Examples for the cRIO must be used a little differently than other examples in the Example Finder.  Please make sure you've reviewed the following document that details how to properly use an example for the cRIO with your particular setup.
Moving Examples to Another FPGA Target
http://zone.ni.com/devzone/cda/tut/p/id/5075
Hope this helps!
Michael G.
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(3,740 Views)
