 MCH170
			MCH170
			06-27-2022 02:21 AM
Hello, I am trying to communicate with the Newport Oriel Cornerstone 260 monochromator via USB. I used its premade VIs to initialize the communication but I keep getting error 90101 "LabVIEW could not return a string from the shared library call". Any ideas? Thanks for your time.
 altenbach
			altenbach
			06-27-2022 04:33 AM
An image of a truncated block diagram containing two generic icons is probably insufficient for us to troubleshoot your problem.
06-28-2022 07:29 AM - edited 06-28-2022 07:30 AM
You're right, sorry about that. Here is the full program (Data_output is the main one), all necessary VIs and dlls are included in one of the 2 folders. Also here is a device manager screenshot of the monochromator driver. Anything else you might need I am happy to send. Thanks for your help.
