Error When Writing to SD Card on cRIO
I am trying to use a SD card to store information acquired by my cRIO-9040.
The SD card in question is an ADATA 16GB UHS-1 microSDHC card with an adapter for SD card size, its default file system is FAT32.
When connecting to the cRIO, I can access the card's contents via the remote file browser (the card's directory is V:) and can download files. However, when attempting to write new data to it, I get error messages.
When trying to create a new folder via remote browser, I get a "403 Forbidden" error.
When trying to create a new text file, from the same method, I get a "500 Internal Server" error.
Finally, when running a VI that creates a new file and stores data to it (I verified that this VI works for USB flash drives), I get an error of code 6.
According to its specifications, the cRIO-9040 supports SDHC cards.
This page says that FAT32 filesystem is both support and recommended: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7iaSAC&l=en-GB
This page also says that 16GB cards are supported (although it specifies SD, not microSD cards): https://www.ni.com/en-gb/support/documentation/supplemental/18/compactrio-industrial-sd-card-accesso...
Does anyone know how to fix this problem? Is it an issue with the card, or with the cRIO?
(2,680 Views)
Got the same errors, but with 64gb SD card. Did you solve your problem?
(2,067 Views)
Accepted by topic author JoseFelgueiras
Greetings,
I eventually solved it, but completely forget to post it.
Essentially, if you are using a micro SD card with adapter, as I was, you have to turn off the switch that puts the card in read-only mode.
Not sure if this will solve your problem. It seems compactRIO does not work with 64GB cards.
(2,064 Views)
