Error code 56 'Time limit'
Hi, everyone:
I am running a project to simulate shoulder abrasion. I've got two VIs from somebody. When I tried one of them today, it worked and gave out the wave- real time displacement, but the other did not work and showed error message like this below:
Error 56: The network operation exceeded the user-specified or system time limit.
Labview version 7.1
National Instrument module: FP-2010
Therefore, how can I change this 'time limit' to make it work, or , is there any other problem with this VI?
Thank you for taking your time.
(3,207 Views)
Do you know what function is generating this error? Is it possible to post the code you are using. Can you access and configure the Fieldpoint device in Measurement and Automation Explorer? For instructions on how to do this goto:
Start»Programs»National Instruments»FieldPoint»FieldPoint Help
Regards
Jon B
NI UK & Ireland
(3,194 Views)
