Error message when I try to run "roaming" on NI robotics starter kit
Hi
When I'm trying to connect my starter kit 2 in Robotics Hardware setup I'm getting unhandling error -63040(nilvFpga_Open_sbRIO-9632.vi)
Regards.
Anthony
(5,682 Views)
Hi anplantin,
Please have a look at these two articles:
Error -63040 When Attempting to Run an FPGA VI on CompactRIO
http://digital.ni.com/public.nsf/allkb/B77CEB8067558F6F86257203007F1E91
NI-RIO Error -63040 when using Open FPGA VI Reference from Host PC
http://digital.ni.com/public.nsf/allkb/83DF7B9245541FC8862573A100597696
I hope it helps!
Kind Regards,
(5,664 Views)
Hi M.Kuznetsov ,
First thanks for your answer. Then I tryed to update the  NI-RIO FCF driver with MAX but I could not find it in the LabVIEW Real-Time Software Wizard .
How I can find this driver ? I use labview robotic 2012 with NRIO 12.0 .
Regards.
Anthony
(5,643 Views)
Hi anplantin,
Firstly you need to format the cRIO.
How Do I Format My Real-Time Target and Reinstall the Software?
http://digital.ni.com/public.nsf/allkb/6B1343F61905203386257051006573CA
Secondly, install the corresponding version of the real-time software:
http://www.ni.com/gettingstarted/setuphardware/compactrio/controllersoftware.htm
I hope it helps.
Kind Regards,
(5,610 Views)
