03-17-2008 11:42 AM
03-21-2008 09:37 AM - edited 03-21-2008 09:39 AM
Hi crock,
What was the order of installation for NI software and drivers? This document: Order of Installation for Multiple National Instruments Hardware and Software Products describes the correct installation procedure, perhaps the software was installed out of order.
The "An error has occurred" is unfortunately a generic error that pops out when there's not a specific error code associated with this behavior. Regarding LabVIEW RT, yes, it should show up as LabVIEW Real Time 8.2.1 in MAX. I've attached my screenshot to this reply.
This issue could be due to many different reasons, but first, I suggest following the KB above and make sure all the software and drivers are installed in order with the same version numbers for extra reliability.
03-27-2008 06:11 PM
03-28-2008 03:25 PM
Hi TMC-NI, As I'm sure you probably already know the Real-Time 8.2.1 module is not on any of the DVDs included in the site license Educational suite. (It's a seperate cd which needs to be purchased.) Fortunetly for us this cd is covered by our site license so NI support promptly zipped it up to their ftp site for a quick download. NI support has been great to work with, are prompt and very professional.
Thanks for your help..
Carymon, | ||
03-31-2008 12:09 AM
Hi Carrymon,
I am sorry for the late reply, friday was a very busy day on my end. So yes, you are right, but I was not sure which version of the Academic bundle you guys had, so it seems at this point that you guys do have the LabVIEW Real-Time version 8.2.1. I am glad the other applications engineer has been able to put that software out for you. Essentially, if you follow the order of install I've described above, you should be able to see the real-time module in MAX as 8.2.1. Let me know if I can help out further.
