Error when trying to deploy a VI into PXI RT target: Invalid value for the Enable Aliasing option
Hello all!
I'm trying to deploy a project on a Real Time target running LabVIEW RT 14 but I'm getting the following error to every shared variable.
Note: The Shared Variable Engine is already installed in the real time target
LabVIEW:  (Hex 0x8BBB0020) Invalid value for the Enable Aliasing option.).
Deploying Variables.lvlib:Test counter\\192.168.0.1\Variables\Variable13 deployment failed (error: -1950679008, LabVIEW:  (Hex 0x8BBB0020) Invalid value for the Enable Aliasing option.
I can't understand the reason of this error or how to fix it because on each variable properties the checkbox to enable aliasing are not checked so the aliasing should not be enabled as it seems be.
How could I fix it?
Message 1 of 1
(2,785 Views)
