Error with dbl data in FPGA
I have a .vi inside a fpga. This .vi has a dbl data tipe inputs, and I can't run the vi because according to the list of errors:  type not supported in current tarjet.
I have a single board RIO (NI-sbRIO-9651-01c18bd6)
Does anyone know what is the problem or a possible solution?
Thanks.
Attached capture of my errors list
Message 1 of 10
(5,349 Views)
Accepted by topic author cristina.lopez
You cannot use DBLs on an FPGA.  Change it to a SGL.
Message 2 of 10
(5,341 Views)
DBLs are not supported on LabVIEW FPGA. Only SGLs and only after a certain version.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 3 of 10
(5,340 Views)
Muchas gracias 🙂
Message 4 of 10
(5,315 Views)
Another question, the fpga can't use the Quotient & Remainder that's right? , how can i do the same operation without Quotient & Remainder
Message 5 of 10
(5,314 Views)
What are you trying to do with the Q&R?  I thought it was available in FPGA, but it is expensive (lots of fabric and multiple clock cycles to complete).
Message 6 of 10
(5,307 Views)
I need to know the remainder and quotient of the division of two variables.
The fuction is in palette but when i put this in block diagram, the error list say me that this fuction is not supported
Message 7 of 10
(5,304 Views)
I want to do this
Message 8 of 10
(5,303 Views)
Quotient-Remainder is not supported in a Single Cycle Timed Loop.
You could do a repeated subtract. It will take multiple cycles but this is how certain functions are on the FPGA. What is the cycle time?
ALE Consultants
Message 9 of 10
(5,296 Views)
Cross post
Message 10 of 10
(5,291 Views)
