Error with lvanlys.dll loading when deploying code on cRIO-9073
Hi All,
I'm actually blocked with my project due to a known deployement error on cRIO-9073. It is related with the "lvanlys" library.
I'm using LabVIEW 9 and each time I try to deploy my code on the cRIO, it terminates with error like "LabVIEW: Failed to load ..... lvanlys .....on RT target device".
I've seen old posts about this problem, but no real solutions. I've also seen that a fix is present in LabVIEW 9 (52841 - 4CMBQFFK - lvanlys.dll causes errors on RT system).
As last test, I've removed from my main VI, all the sub-VIs that contain calls to this lvanlys library and the deployement is ok.
Thanks for your ideas & help.
Synthesis
(4,026 Views)
Hi Synthesis,
- Is the problem still there if you reboot your cRIO?
- Did you try to reinstall the SW on your RT target (format drive>reinstall SW) ? This could probably arise because of a software corruption on the target.
Cheggers
Sascha
(4,005 Views)
Setting the NI RIO Software version on the target to 3.2.1 (minimal) fixes this problem.
(3,492 Views)
