EtherCAT Problems
I was trying to settle an EtherCAT connection with NI cRIO-9037 as the EtherCAT master and a third-party EtherCAT slave from Gantner Instruments (Q.Station 101 T), when i try to enter the active mode in the scan engine, it shows the error HEX: 0x8005442C, on the other hand if i try to manually switch the slave to safe operational state or even to bootstrap state, it shows another error (-2147138493 or in HEX: 0x80054443).
I am utilizing:
  1. LabVIEW 2016
  2. LabVIEW 2016 real time
  3. NI-Industrial communication for EtherCAT 18.5
  4. NI RIO 18.5
  5. NI scan engine 5.0
I haven't done a single block of code, i have updated both the Firmware of the cRIO and the slave in their respective softwares. The master perfectly detects the slave, so i do not think it could be the ESI File, however it won't go to the active mode of the scan engine. Could anyone lend me hand please?
(3,930 Views)
Have you tried reformatting and reinstalling the software again?
(3,874 Views)
Hi Nicolas_loupe,
Could you provide the Wireshark log and ESI file with me? I could help to resolve this problem when I get these files.
Thanks!
(3,869 Views)
Did you solve this problem?
I have now the same thing with MAXPOS 50/5.
Hope you see this and can reply to me!
Thank you.
(3,526 Views)
Anyone solved this problem?
(2,985 Views)
In my case it was caused by the wrong address of the variable in the xml file.
I wrote the subindex in hexadecimal value while it was required in decimal value.
Check that the variables declared in the RxPDO and TxPDO of the file have the correct address.
(2,820 Views)
