Explorer not displaying resource
Sorry I do not know where else to post this basic question
Explorer shows my oscilloscope resource but it does not display. I have tried all usb ports.
Any help would be very much appreciated.
Message 1 of 18
(5,819 Views)
Does this information help in solving the problem?
Message 2 of 18
(5,795 Views)
Is this an NI Scope? Or is it a third party scope you're trying to connect to with MAX? Could you send a picture of what you're referring to in regards to the oscilloscope resource showing but not displaying?
Eden K
Message 3 of 18
(5,784 Views)
Thanks for taking the time to consider my problem.
I'm using a 3rd party digital scope viz., Siglent SDS 1102CML.
The absent display is in the IO Trace window, ie., my 2nd posted image, which at present contains the red error data, amongst other things, but normally my scope image.
The Trace window worked sometime ago but hasn't since I moved the location of my computer, nothwithstanding that I have since tried to get back to the now unknown usb port that I originally used.
Cheers
Message 4 of 18
(5,764 Views)
Could you include a screenshot of your code where you're trying to run those commands? And to make sure I'm following, are you saying that you expect to see an image of the scope in the I/O Trace window?
Eden K
Message 5 of 18
(5,758 Views)
No code is required to capture the scope image, just right click the scope reference in the left hand window to display the IO trace window.
Should be as simple as that, and has worked in the past..
Message 6 of 18
(5,748 Views)
Hey dalpets,
There is some code required in opening the resource, sending the VISA commands, etc, is there not? Is your issue solely that you cannot get the scope image? Are you able to get other information properly from the scope with VISA?
Eden K
Message 7 of 18
(5,731 Views)
@WestOfEden wrote:
Hey dalpets,
When  some time ago I first used this setup, I spoke to support, and I recall nothing was said about  code, just that I needed to select the right usb port to get it working.
Yes, my issue is solely that I cannot get the scope image.Haven't tried getting other information.
I've now installed the software on another computer. Same problem.
Thanks for your help.
Message 8 of 18
(5,719 Views)
Where are you selecting this USB port? How are you selecting and sending the commands to send to the scope?
Eden K
Message 9 of 18
(5,699 Views)
Selection by physically trying each port on the computer, not in the NI software.
Message 10 of 18
(5,696 Views)
