External Memory FAT32 file count restriction?
I am currently working on a project were I am streaming data acquired with different cRIO modules to an external HDD connected to the cRIO (9024).
The measurement has to be continous with up to 50kS/s/Ch. The connected HDD is formated in FAT32 and working fine in the beginning of the measurement.
I save the data to binary files directly on the ext. HDD and create a new file every 5mins.
The code is working fine for the first couple of hours but at some point it crashes. I think there is a relation to the number of files on the external HDD.
While debugging i found out that the "Open/Create/Replace File" VI takes more and more time when there are more files in that folder.
I can not create larger files (more then 5mins each) because then i get another problem with the 4Gb restriction of one files with FAT32.
The crashes usually happen when there are around 1000 files.
Is there a way to work around this issue? Does anybody has the same experiences with streaming to external HDD on cRIO?
Best Regards
Gerd
(5,317 Views)
when using fat32, the maximum number of entries in a folder is 65,534.
But you have to be careful, since depending on the lenght of each file and subdirectory it can take more entries. (from 2 to 13 entries)
Reference:
ntfs vs fat
FAT 32 spec
I don't know how you structured your folder but 1000 files shouldn't be enough to exceed the file count limit.
In your case I guess it's a performance issue. Because an index list is created as well for every folder. So the performance will drop rapidly when you reach a big amount of files.
You could try to change the directory after a few hundred files.
(5,302 Views)
