FATAL_ERROR:Xstortability/export/Port_Main.h:127:1.17
I get  FATAL_ERROR:Xstortability/export/Port_Main.h:127:1.17 when i compile my program in FPGA 8.5 The program compiled in FPGA8.2 It contains arrays but as I sad it Worked in 8.2
 use a CompactRio 9014 Controller, 9102 Chassi and NI 9205 Input modules.
See Attached file: Compilelist
I foundReport 3YJFMUNQ . The suggested solution is to add the synthesis token "keep_hierarch SOFT"
Now the compiler comiles with warnings ?
See Attached file: Compile with warnings
(5,346 Views)
Hello!
I looked around at Xilinx’s webpage and our portal in order to find information about the error you are receiving and I didn’t find much but at least some.
First a NI document that describes the error you are receiving and how to get rid of it:
Compile Failure Port_Main.h:127:1.16 or Port_Main.h.127:1:17 for a variety of designs.
http://digital.ni.com/public.nsf/allkb/3737F8EB7179A206862572EC0073A3E9
Somewhat related document at Xilinx:
http://www.xilinx.com/support/answers/24978.htm
We implement changes every now and then in the NI-RIO driver in order to support new targets and such and I know that applications where there they synchronized multiple chassis didn’t work with a certain version of NI-RIO but that was later on fixed.
Which version of NI-RIO are you currently using?
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(5,279 Views)
I use NI-Rio 2.3.1
I use three Compact RIO but they do not communicate with each other, ontly with th PC.
(5,272 Views)
OK, so you are using the latest version of NI-RIO. Did you try the workaround described in the NI link above? If that doesn't solve the issue I believe we need the code so we can reproduce the problems you are experiencing.
Jimmie Adolph
(5,268 Views)
When I followed the advice from National Instrument. I can compile and a application similar to the first one works, but I get warnings. This warnings are included in the file compile with warnings. The advice from XILINX is that I should upgrade some softwara that I do not know what it is. I nead more guidance from National Instruments to uppgrade the National instruments software with the XILINX software. Preferable you should include this uppgrade in a FPGA upgrade.
(5,253 Views)
