FPGA Compilation Error
I am trying to compile my MainFPGA VI using Labview 17. The code worked fine on Labview 16. During compilation i get a PopUp-Window "MEM.BAD.POINTER" and the compilation stops. The compilation status summary says:
"LabVIEW FPGA: Some of the compilation steps were not executed.
Refer to the Xilinx Log report for more information or contact National Instruments technical support at ni.com/support."
The last message on the Xilinx log is:
Finished Writing Synthesis Report : Time (s): cpu = 00:03:34 ; elapsed = 00:04:06 . Memory (MB): peak = 1000.086 ; gain = 614.223
Synthesis finished with 0 errors, 0 critical warnings and 1320 warnings."
I think it is kind of an compatibility error between LabView 16 and 17.
Reinstalling the Xilinx compiler didn't help and on other PCs i get the same errors.
Do you have any ideas how to fix the problem?
Thanks in advance!
(2,563 Views)
Do you use maybe Windows 10?
Check THIS KB. This error is a Windows Error and can occur because of the incompatibility between Windows 10 and Xilinx tools.
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,477 Views)
