FPGA IO Nodes don't display correctly in 2009f3
Just a minor bug with work around.
When opening existing FPGA code in 2009 (f3), none of the the bottom borders of the IO nodes are displayed.
If you stretch the IO node down to add another IO element, then stretch it back, the border displays correctly.
(3,674 Views)
Chris,
Thanks for taking the time to let us know. What version did you upgrade from? I'd like to look into this.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,652 Views)
I just upgraded from 2009f2.  I can't say for sure that it wasn't there, but I did not notice it.  (This is subtle however).  Before that it was 2009f1 which I'm sure did not have the issue.
(3,644 Views)
Same here, upgrade from 2009 to f1, f2, f3.
Seem to recall it happening in f2 as well, but might be mistaken.
Cheers
Stephen
(3,641 Views)
I had my coworker send me a VI built in f2. I opened in SP1 and I did not see the clipping. I am going to convince him to go to f3 so I can check it out, but this may be fixed in SP1 based on this finding.
Rob K
(3,617 Views)
