FPGA SCTL: Not Gate change timing of the Digital output signal
Hello All,
 I am struggle with the timing of the output signal while trying to generate differential signal out put pair. I suppose was simple as add a not gate to the first signal then I can can have the 2nd signal revert.  Well, it did revert but the timing is off.  they are not out put at the same time.  One is delay a haft cycle time compare to the other.  This is execute in a SCTL.  Any idea?
Tphan
(2,394 Views)
What hardware are you using (model?)
Some DIO to DIO skew is to be expected. It might be random and vary from bit file to bit file. See https://www.ni.com/en/support/documentation/supplemental/11/rio-mezzanine-card-digital-i-o-capabilit...
 Also, it might be useful to post a code snippet or maybe a VI and project just so to be totally sure there's no issues there.
(2,357 Views)
I am using SBRIO -9606 + NI9694..  I don't have a scope right now but all data is read back from the hardware it self.  I am not sure the delay is real until I got a Oscope to check them.  It could be that the delay happen in the read back process.
Tphan
(2,351 Views)
