FPGA Type Cast SGL
I am using a DMA to pass data up and down between my FPGA and my RT (cRIO).  I made the DMA data type a U64.  My intent was to use 16 bits for a command ID, another 16 bits for a signal ID, and then make the lower 32 bits the data.  My data is supposed to be passed around as a SGL and then converted into the Fixed-Point inside of the FPGA (which I was told was more efficient).  The problem I have ran into is that I have no way to type cast the SGL into a U32 to then be joined with my message.
I did manage to make an IP node based on the example given here.  But that just seems like a kludge to me.  There has got be be a better way.  Anybody know of a better way?  All I really want is to reinterpret the bits as a U32.
(7,061 Views)
I've only done this with the VHDL provided by Dragis here: http://forums.ni.com/t5/LabVIEW/Flatten-floating-point-on-FPGA-for-multichannel-DMA/m-p/2576179#M776...
While it's slightly different HDL, it's the exact same thing you're trying to avoid here...
To the best of my knowledge, it's not a language feature available on the palettes anywhere. I also don't see it on the idea exchange yet.
Cheers!
TJ G
(7,059 Views)
It is now.
(7,052 Views)
I needed U32 to typecset to SGL type DMA channel.
I had to created this IP code:
https://decibel.ni.com/content/docs/DOC-26569
you needed same only in opposite way
I am working for your Idea
(6,829 Views)
Yeah, we did find that one as well.  We went with the code by Dragis since it was written to be a little more generic.  Still not happy that we have to go with an IP node for something that should take 0 gates.
(6,828 Views)
Hi, Having the same issue, I've found this archived note ( Using Fixed-Point Data Types with Integer-Based IP in LabVIEW FPGA 8.5.x and 8.6.x ).
I think this may less kludge.
(5,504 Views)
The problem with that is that you have to coerce the SGL to a FXP.  I wanted to put my SGL directly into my message, which was a U64 sent over a DMA FIFO.
(5,482 Views)
