FPGA compile Error
cRio-9082
Windows 7
LabView 2014 with FPGA
When compile my FPGA code, error occurred. See attached file.
Please help!
Thanks!
(2,505 Views)
Hi LUX,
Is this the first time that you have encountered this error?
Do you have any firewalls up? I would check your firewall setting and ensure that this is nothing impeding your communication that way.
The document below is for general FPGA Compile Farm errors; you can look through this to see if any steps are helpful.
LabVIEW FPGA Compile Server Errors
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9NPSA0
Thanks!
Erika
Technical Support Engineer
(2,484 Views)
