FPGA: max Value from Array
Hi Guys,
am reading numerical data from a Signalgenerator, via FPGA. The data is displayed in real time on a front pannel indiactor and historically on afront pannel chart.
I want to display the max of the realtime data on the front pannel, i apriciate that to do this i need to store the data as i go (perhaps in an array?)
So how can i build up samples and display the max and index of this data ?
cheers mehmet
(4,502 Views)
Hello mehmet,
If I understand your application correctly you will have to store the last 1024 values
somehow (e.g. in an array). However, I think it is more practicable to do this form
of analyziation in the real-time host VI.
  Georg
(4,479 Views)
hi georg,
thanks, you are right. i can do this in the real time host VI ,even it is much easier, but it takes time.
(4,462 Views)
It should not take too much time if you do it efficiently. You could try something like this:
(4,458 Views)
i must send them first to Host VI , then again into FPGA VI for further processing ; it takes time .i m trying to find another solution at the moment. thank you for your help
(4,451 Views)
