FTP file transfer and retriebal
Can anyone tell me what exactly I'm doing wrong in this FTP Get File VI. I keep getting error 7.
(4,625 Views)
Hello madmex55,
Does the error also have a description that explains which part of the function LabVIEW was unable to handle?  This error could be thrown for a number of reasons:
1. Typically Error 7 is thrown when LabVIEW cannot locate the file you are requesting.  In this case, the error could be due to your remote path or your local path references.  Could you double-check that these are correct?
2. The FTP server is disabled by default on your Real-Time target and you cannot use it in safe mode.  Ensure that you have manually installed the FTP server to your target using the Add/Remove Software feature in NI MAX. This may be helpful:
http://digital.ni.com/public.nsf/allkb/A9CC22F64DE9490186257B8D006A6C18
3. Also, FTP is deprecated as of 2013, so NI recommends using WebDAV as the file transfer mechanism for improved security. These documents might be helpful:
http://digital.ni.com/public.nsf/allkb/C242CF9F0512DF6186257434000DBCBA
http://digital.ni.com/public.nsf/websearch/4EBE45E8A816B19386257B6C0071D025?OpenDocument
I hope this helps!
Nadine H.
(4,602 Views)
