Failed to load shared library lvanlys.*
I am using a NI-cRIO-9073 and I am trying to deploy a VI that uses the nD Nonlinear System Solver VI in VI instance mode. I know that I am using it correctly, because I have deployed this same VI to this same CRIO before.
For some reason, it stopped working, and I cannot even deploy my VI to the CRIO anymore. **If I use a diagram disable to disable the nD Nonlinear System Solver VI, it will deploy no problem.**
The errors that I'm getting are:
Deploying NI_AALBase.lvlib:Real Inverse Matrix.viNIAALBase.lvlib:Real Inverse Matrix.vi loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library lvanlys.*:InvMatrixTriDri_head:C. Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
LabVIEW: Failed to load shared library lvanlys.*:InvMatrixLUDri_head:C. Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
LabVIEW: Failed to load shared library lvanlys.*:InvMatrixChoDri_head:C. Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
I can look at my CRIO file system, and I can see that the lvanalys.out file in in the ni-rt/system directory. It is weird to me that this used to work but now all of a sudden I cannot deploy it. I have tried creating new projects with the same source code and that does not work.
Somebody help me please!
(3,358 Views)
Hi there,
Have you tried removing and reinstalling the software on your cRIO?
Do you have another cRIO that you can try to duplicate the issue in?
(3,320 Views)
Yes, I have formatted the cRIO several times, and then reinstalled different combinations of software add-ons. Speaking to NI Support that library is one that should be a part of the built-in software options (not an add-on I should have to add). I have FTP'ed into the device and confirmed that the lvanlys.out file IS there. So I cannot understand why the VI can't find it.
(3,317 Views)
