Firewire with Real Time
I am attempting to use twelve firewire cameras on a real time slave connecting them to the computer using three firewire cards with 4 inputs each. After connecting it all and accessing the slave on another computer using MAX It recognizes every camera. To avoid bandwith problems I reduced the frame rate to 15 using 640x480 resolution. The problem is when i attempt to capture sometimes (on random cameras) I get a timeout error. Any ideas on why this happens?
(4,255 Views)
From how many cameras are you trying to get an image at the same time ? I think it is possible that the bandwith is not big enough.
(4,209 Views)
We are trying to capture from all cameras (12) simultaniosly. But we did the math and it's not a bandwidth problem...
(4,207 Views)
Well, ok does it still happen when you reduce the number of cameras ?
(4,203 Views)
If we remove 2 of them leaving 10 cameras it works perfectly... Any idea why?
(4,201 Views)
Well, I don't have any idea for now, timeout errors are not easy to resolve. Did you take a look at this link ? http://zone.ni.com/devzone/cda/tut/p/id/2977 Especially the part about packet size.
Message Edité par Maxime MULLER le 07-11-2008 08:52 AM
(4,198 Views)
