Flex RIO PXIe-7972R, Target to Host Continuous Transfer Speed,Maximum?
What is a reasonable fastest continuous DMA Target  to Host data transfer rate I can run?
(1,621 Views)
Depends on chassis, controller, and operating system configuration.
With a 7976 I've seen 900 MB/sec but this was limited by the disk.  The 7972 is similar.
The shipping example "High Throughput Streaming.lvproj" is able to run tests up to 2 GB/sec.
Do you have your hardware?  You can run this example.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,600 Views)
Thanks for the response....I'll take a look at "High Throughput Streaming.lvproj" once I have my hardware setup.
At this point of my design I am trying to figure out what is a reasonable data rate
Hardware this will run on is
  • PXIe-1095, 18-Slot 3U PXI Express Chassis
  • PXIe-8880, Xeon 8-core 2.3 GHz controller, Red Hat
  •  6 PXIe-7972R, FlexRIO FPGA Module
  • PXIe-8240, 40 Gb Ethernet Interface Module
I need to stream from one of the FlexRIOs back to the controller (which then sends it to the Ethernet Module)
If I don't compress I need to pass 32bit words at 20MHz......while other bus operations are happening on the other 5 FlexRIO
(1,580 Views)
