05-05-2011 07:15 AM
is there a solution for formatting a cRIO remotely without actuation of the Safe Mode switch? We have several cRIOs running several hours away which sometimes hang up during deployment rendering the system inoperable.
For cFP i found this thread:
How do I Boot cFP-2200 into safemode remotely?
But in my MAX (V. 4.7) i don't see the option "Force Safe Mode". Is this specific for cFP?
Any Ideas?
Simo
05-06-2011 03:12 AM
Hi Simo,
The KB was specific for cFP, so you cant use this one on cRIO.
I dont think there is a solution for that one. On cRIO its necessary to switch the dip!
I hope this helps, RMathews
05-06-2011 03:29 AM
Thanks.
Seems I have to develop a remote dip switch actuator one day...
05-06-2011 03:35 AM
Sounds like a good plan to me ![]()
05-23-2011
12:29 PM
- last edited on
03-27-2025
07:50 PM
by
Content Cleaner
For the 9075/9076 (the controller does not have dip switches) you can configure the system to be in safemode in MAX (or by pressing the reset button).
Also, depending on what kind of controller you have and what you need to do, you may not need safe mode.
