GPS signal interference high voltage line
Hi Engineers,
I want to install a cRIO, as a PMU with time stamping using a GPS module added. The problem is with the place that i need to mount your device is inside a kiosk at a high voltage (400kV) switch yard. Can i mount the GPS antenna above the kiosk, given the 400kV lines would be passing above it (approx. 10-15 meter)? Will there be an interference due to the high tension line on the GPS signals? Will it affect the device on a long run?
Message 1 of 1
(5,608 Views)
