Generating executable scan engine mode
I've developed a software using Labview Scan mode engine. There's a main that will run on the PC and no VI embedded. I need to generate an executable and run it on a PC that doesn't have Labview installed. I want to know if I have to deploy something on the cRIO, and if I have to configure the cRIO on MAX on the PC that it will run, or if not, how do I configure it?
(4,634 Views)
Hi Thuany,
Well, the dependencies of the Windows Application will depend on how you programmed your VIs. Can you post your Project so that I can see how you did it and provide you a better answer?
Felipe Flores
Technical Support Engineer
(4,587 Views)
Hi Thuany,
Felipe Flores
(4,586 Views)
