Getting NTP option on RT Controller
Hi all,
I'm trying to sync my real time controller to a NTP server.
I followed all the instructions on the following below link, but wasn't able to get the time sync to work.
https://forums.ni.com/t5/Sync-Labs/TimeSync-for-SNTP-Getting-Started/gpm-p/3543825
The problem is when I installed timesync, the instructions told me to modify the file "/ni-rt/system/ni-timesync/ni-timesync-sntp.ini" which is nowhere to be found in the ni-timesync folder. I was able to find the ptp ini file but not the sntp. Do I have to create the ini file myself or should it have been created when I installed timesync program into my real time controller?
Any help would be useful! Thanks!
(4,064 Views)
are you talking about the linux-based boxes (eg. cRIO-9064) ?
-> http://www.ntp.org/downloads.html
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,983 Views)
Hi
First thing that comes to mind is that your controller might not running VxWorks or Phar Lap OS.
Which cRIO are you using?
BTW here is a KB that can help you figure out what OS is running on your cRIO
http://digital.ni.com/public.nsf/allkb/35F1FD98520D6E0E8625783A005AF557
(3,961 Views)
http://doc.ntp.org/4.1.2/hints/vxworks.htm
No idea about pharlap's strange partial win32 clone (if one really looks for win32 clones - go for reactos), but if they still even requires reboot for trivial things like timezone changes, I wouldn't expect anything useful related to time synchronization.
(3,955 Views)
Here are a couple of options if your OS is Linux RT
Installing and Configuring NTP on NI Linux Real-Time Devices
http://forums.ni.com/t5/Example-Program-Drafts/Installing-and-Configuring-NTP-on-NI-Linux-Real-Time-...
Some people have also had success by using this program to set the time.
Solved: Re: Permissions: Setting date/time with system exec or script
http://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/Permissions-Setting-date-time-with-system-exe...
Eric
(3,932 Views)
time/clock handling is a can of worms:
(3,927 Views)
