Getting cRIO NI9147 to run an FPGA VI idependantly
I've successfully programmed my FPGA to handle all our RIO's I/Os, but I'd like the RIO to run independently of my computer. Is it possible to get the FPGA to execute the program on it's own, preferably without using real-time?
(2,843 Views)
I'd take a look in this article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mASAS
It should help you setup your FPGA code to run when the device boots instead of triggering it from your computer.
Tyler O.
(2,812 Views)
Hi Tyler,
The article you linked was the one I based this project off of, but I'm convinced there are some steps missing from that article, because I was able to get my RIO program working using LabVIEW run time, and conveniently when I powered up the FPGA this morning while it was unplugged for the host computer, it just worked. Until that is I tried updating the the FPGA software and it went back to need the host computer. Now I'm not sure which of the many settings I messed with caused it to work, but if anyone knows what the correct settings are that would be extremely helpful.
  • Scan Mode or FPGA Mode?
  • Do you load the software onto the RIO from the Project interface or by loading the bitfile with the RIO device setup tool?
  • Does compiling by running a build from you build specifications automatically load the software onto the FPGA?
(2,808 Views)
