Hardware timed single point acquisition using ANSI C
I'd like to perform  HDTSP acquisition in the ANSI C enviroment. The code is listed in the following. would you please help me check it? I think there is some mistake because i cannot excuate it.
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
 int32       error=0,read=1;
 bool32 islate=0;
 float64 data[1];
 TaskHandle  AItaskHandle=0;
 char        errBuff[2048]={'\0'};
 // DAQmx AI Configure Code
 DAQmxErrChk (DAQmxCreateTask("",&AItaskHandle));
 DAQmxErrChk (DAQmxCreateAIVoltageChan(AItaskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
 DAQmxErrChk (DAQmxCfgSampClkTiming(AItaskHandle,"",5000.0,DAQmx_Val_Rising,DAQmx_Val_HWTimedSinglePoint,0));
 // DAQmx Start Code
 DAQmxErrChk (DAQmxStartTask(AItaskHandle));
 // DAQmx Read Code
 while(islate==0)
 DAQmxErrChk (DAQmxReadAnalogF64(AItaskHandle,DAQmx_Val_Auto,10.0,DAQmx_Val_GroupByChannel,data,1,&read,NULL));
 printf("%f\n",data[0]);
    DAQmxErrChk (DAQmxWaitForNextSampleClock (AItaskHandle,10,&islate));
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
 if( AItaskHandle!=0) {
  // DAQmx Stop Code
  DAQmxStopTask(AItaskHandle);
  DAQmxClearTask(AItaskHandle);
  printf("DAQmx Error: %s\n",errBuff);
 printf("End of program, press Enter key to quit\n");
 getchar();
 return 0;
Message 1 of 1
(3,675 Views)
