Help!Manually set the ethernet port speed on cRIO 9012 controller.
Hi! I need to manually set the ethernet port speed to 10 Mb on cRIO 9012 controller. Is anyone knows solution? Maybe VxWorks ethernet driver have any hidden configuration params?
(4,189 Views)
The version of NI-RIO that your controller is compadible with does not have teh functionally of constraining the ethernet port to 10Mb.  You can also get more information here http://forums.ni.com/ni/board/message?board.id=140&message.id=38686&requireLogin=False
(4,172 Views)
Thanks for reply!May be you know the version of NI-RIO that compatible to this option?
(4,169 Views)
The versions of NI-RIO that have that option to set the ethernet speed aren't available to download and aren't recommended to be used with your cRIO-9012
(4,154 Views)
