Help - is there any code to run NI4350 using Delphi?
I'm looking for a simple program code to bild a Delphi 4 project running the ni4350
(4,419 Views)
We do not have any pre-written examples specifically for Delphi using the NI-435X instrument driver. However, the NI-435X cd allows you to install support for C based programming languages, and all you would need to do is open one of these examples and make the same function calls to the NI-435X driver, just in a different programming environment.
(4,419 Views)
