High speed data logging with Pharlap
Has anyone tried logging high speed with a pharlap target? My first instinct is to attach a USB SSD drive. Does Phalap support USB3 transfer speeds? The file format doesn't support large file sizes right? How much of a PITA is that?
(2,472 Views)
What hardware are we talking about? Our PXI controller for example runs on Pharlap and it is indeed possible to log data deterministically.
(2,450 Views)
Yes, PXIe 8821 RT. What sort of rates can I expect to a USB3 SSD? FYI, I don’t need determinism for this part of the application.
Is there a better option for throughput than a USB3 SSD?
(2,444 Views)
That PXI controller should have also memory on its own. So you can conveniently save data on it while measuring, by writing data onto a text file for example. Now, if you require very large amounts of data, I suggest that you "pull" them periodically from the PXI or with some sort of a buffer over Ethernet / USB. But keep in mind, that your device  should have quite some memory available
(2,437 Views)
Yes, I'd like to be able to store large records. Maybe up to 100GB. The reason I'm interested in USB3 speeds is I'm looking to transfer at a higher bandwidth than gigabit ethernet can provide. Does anyone have experience here?
(2,431 Views)
