How I can reduce the noise
goal: reduce the noise
I store the samples of one sensor into one file, I can read it and obtain this samples in one array. I need to reduce the noise of this sample.
How I can to do it???
If I use a filter for it, with which parameters must I configured the filter??? and which type of filter I must use???
Is there any other way to reduce the noise without one filter??? I could to try to do it by this way.
Gonzalo
(3,457 Views)
If you want to reduce the noise without an analog or digital filter, you can smooth your data by doing a mean on several values.
Regards
Pierre R...
Certified LabVIEW Developer
(3,420 Views)
if you remove the noise source  you would solve your problem !
Unfortunately we don't live  in a perfect world. Noise is an accepted part of our daily measurementsSmiley Mad
Your description why apparently concise for your problemSmiley Wink
 is vague with regard to what you are trying to achieve and how  your measurement is set up.
xseadog
(3,350 Views)
