How can I change the RTD wire mode or RTD on a 9216 when using in FPGA mode
I checked property nodes, invoke nodes, property of the card..no option to select the RTD mode or which RTD is being used when used on the FPGA on a cRIO.
Is this even possible?
(3,234 Views)
Accepted by topic author labviewman
As detailed on the specifications of the 9216 it should automatically detect if you are using a 3 or 4 wire RTD and configure the channel appropriately based on that. You can find it on page 1 of the datasheet.
http://www.ni.com/pdf/manuals/378022a_02.pdf
(3,204 Views)
Oh, OK. But does it also select the RTD type automatically (we are using a supported RTD)?  I don't see this in the manual (for FPGA) but you can select this in scan-mode, I suspect while in FPGA mode, it defaults to a certain type of RTD, which is quite limiting (there are several RTDs that I know of that have a nominal resistance of 100 ohms).  See attached picture.
When I used the module on the FPGA, the reading returned the resistance of the RTD.
(3,202 Views)
I think I found a solution...an example VI in LabVIEW shows the FPGA returns the resistance and you have to do the conversion in RT.  This makes sense...I should have looked at the examples first!
Thanks!
(3,200 Views)
