How can I change the tcp maximum segment lifetime (MSL) on an RT Linux target
I'm running into an issue where my server is getting stuck in FIN_WAIT_2 for many minutes. It eventually does drop the connection (expected behavior) but I'd rather it dropped the connection after maybe just a few minutes. A brief reading of the TCP protocol tells me I have to reduce the MSL. Is there a recommended way of doing that?
(5,586 Views)
Modifying the MSL on a Linx RT target is not supported by National Instruments, so we do not reccommend a specific way of doing that. I was able to find a couple of helpful third-party resources (linked below) that will allow you to modify the MSL.
Stack Overflow: What is Maximum Segment Life
How can I change Maximum segment lifetime in Ubuntu 14.04
Aaron Douglass
(5,535 Views)
