How can I get the base address of the PCI-6025E board when programming in the registr-level?
Any suggestions or examples?
(5,192 Views)
Have you visited the DAQ Register Level Programming Resource page? You can find it at:
http://www.ni.com/support/daq/program/reg_prog.htm
This page will provide you with the resources that you need to register program a PCI E-Series board.
Erin
(5,192 Views)
This is a PNP type card. So the BIOS will asssign a BaseAddress in the reserved Address range during the startup. you can find it on the device management area (BAR1).
(5,192 Views)
