How do I move my program from my computer to my cRIO
I've noticed that my program slows down on the computer over time. I'd like to move it to the cRIO I have. How do I do this?
(5,496 Views)
Accepted by topic author BioProcessNU
When you are working with cRIO you normally have your main code running on your cRIO target and a graphical user interface running in your host computer (if needed).
If you want to move your main code to the cRIO you need to identify what part of your code can be placed on it. Once you've done this, you have to create a project and develop the application that will be deployed on the cRIO. You can use this article as a reference to develop your application.
Miguel Fonseca
(5,488 Views)
