You can program one of the counters to generate a continuous pulse train. Once programmed to do so the counter needs no further interaction. It will continue to generate the signal until stopped through SW. So you can start the counter using the functions provided to you, then forget about it and program the AI operations.
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
