How do I set up analog input for sbRIO 9641?
I'm trying to set up analog inputs on the sbRIO 9641, and I don't see how to place the analog input nodes in my fpga VI. All that I see is the onboard I/O digital ports (Port 1-9) and Mods A-D. It looks like Mod A has some analog inputs, but when I hook them up to a waveform graph, all that shows up is random noise. On the hardware side, I'm testing with a simple sine wave set up in as a referenced single-ended measurement (as per the user manual).
Does anyone have an idea why this isn't working? An example VI would be really nice, if anyone had time.
Thanks alot.
--Sean O'Hara
(4,030 Views)
Good Evening Sean,
The Analog Inputs that you see listed under Mod 1 in the I/O Node are the correct ones.  For further configuration options, right-click on ModA in your Project Explorer and select Properties.  You will be able to configure each channel for the hardware configuration that you wish to use.
(4,005 Views)
