How many CAN ports available on 9606
Except for CAN0, is there any CAN port on RMC connector? Since the processor of MPC5125 has 4 CAN ports, can I use all of these ports?
(5,369 Views)
If you have an EEPROM you can configure the GPIO on the RMC to support CAN One Network on pins GP_Port(0, 1, 5)
(5,138 Views)
Hi newbear,
The capabilities that Jeff mentioned are detailed in the latest version of the sbRIO-9606 user manual:
https://www.ni.com/docs/en-US/bundle/sbrio-9605-9606-9623-9626-9633-9636-seri/resource/373378d.pdf
The CAN and other peripherals built into the PPC are multiplexed.  Most of the processor IO pins are already used for onboard tasks (Ethernet, Serial, USB, RAM, Flash, bus to FPGA, etc), but with an RMC with onboard configuration EEPROM, you can dedicate the pins Jeff mentioned as a second CAN port.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(5,134 Views)
