How measure 65 order Harmonics by using FFT VI
Hi I measure the 65 order harmonics by using harmonics VI in cRIO (in the real time part) but the program after using this VI is very slowly ((300 ms) i need faster that (20 ms))So I need measure the 65 order harmonics in the FPGA by using FFT VI.How measure the 65 order harmonics by using FFT VI in the FPGA? Thanks
(3,310 Views)
Hi Spring,
Have you taken a look at the Advanced Harmonic Analyzer Measurement.vi . This vi seems to do basically the same thing you want to do.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(3,285 Views)
