How to Create Adder, LPF and HPF, Amplifier Circuits in FPGA LabVIEW
Hello, I have NI cRIO 9024 with NI 9215 and NI 9263.
I want to design a digital signal processing circuit with the following sequence
From Sensor 04 Voltages will be Received at AI0-3 Module > I want to Add These 04 Signals > Amplified Them > Pass Them Through Low Pass Filter >> Normalize My Final Output
Currently, all the above operations are being performed by Analog Circuit which contains opamps, resistors, and capacitors. How can I replace all these using LabVIEW?
I don't know if my Question is posted on the right platform or not but I am not sure how to ask for help. Please someone should suggest me how to start with my task.
ThanK you all
Best Regards
Umair
Message 1 of 1
(1,193 Views)
