How to Plot Linear fit for only given intervals of x in xy plot
I want to a plot a linear fit as shown (in cyan) between the x axis values as choosen which should be user defined .  I tried to filter out the x axis array greater than lower limit and less than upper limit and plot but due to rest  of data in array as NaN the linear fit doesnt work.
please help!!
(2,084 Views)
Hello JP187,
How did you filter given portion of array?
Why you haven't use subtract portion function?
Could you please attach the the code?
__________________________________________
The best way to thank, is to give KUDOS
(1,899 Views)
