How to convert aco file (binary) to lvm file ?
Dear All,
I have a real-time pressure measurement and saved in aco file (binary file). Now I want to convert it to real-time lvm file. Did anyone know how to do it? I posted my Labview vi used to convert the data. However, after conversion, the number of samples are not the right one. For example, I took the pressure measurement (single channel) with a 10000 sampling rate and recorded 60 seconds. That is to say, there are supposed to be 60*10000 samples. However, the Labview vi developed only provide 5012 samples. It is very weird.
Could you please help me to fix the problem?
Many Thanks
Probie
Message Edited by 128 on 09-29-2009 02:24 AM
(3,467 Views)
Problem is solved.
Cheers
(3,463 Views)
