How to get Data rate in drop down menu of FPGA I/O Property Node NI9233
I am truying to replicate Example from C:\Program Files\National Instruments\LabVIEW 8.6\examples\CompactRIO\Module Specific\NI 9233\NI 9233 Getting Started.
I am stuck at the very beginning of it. When I right click on FPGA I/O Property Node and choose SELECT PROPERTY I could see only LSB Weight and Offset options no Data Rate. What should I do to see it?
I am using  NI cRIO -9072 with NI 9211, Ni  9233, NI 9263 and LabView 8.6 with FPGA and Real time modules.
(3,659 Views)
In your example the property node is referencing a specific channel on the 9233, not the 9233 as a whole. The Data Rate is a property of the module, not the channel. Set the property node to the module and then you have the Data Rate property.
9233 Data Rate Property
Message Edited by Christian L on 08-13-2008 01:09 PM
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,649 Views)
Thanks. It helped.
(3,629 Views)
