How to get MGC 647C to communicate with Baratron 627B to read pressure??
I am working with LabVIEW to communicate with MKS MGC 647C to read and display the gas flow in chart and table form. Now I am trying to read the pressure from the pressure gauge Baratron 627B but it is not being recognized by the MGC which it is hooked up to via the pressure port on the MGC. Is this an impossible task? Help is much needed and appreciated! Thanks in advance!
(5,790 Views)
Have you visited this page? http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=4736
Do you have the right drivers downloaded for MKS MGC 647C? Is the problem for LabVIEW not recognizing the controller, or the controller not recognizing the pressure gauge? If thats the case you can contact MKS instruments too. They might have some ideas as well.
(5,780 Views)
I have contacted MKS. The drivers are all working, the problem is the pressure gauge is not being recognized. I am currently awaiting a response from the company now. Thank you for the link and for your response!
(5,773 Views)
No problem, good luck.
(5,766 Views)
Thanks! :womanhappy:
(5,713 Views)
